My Jensen A540 turntable chipper has an overrun/freewheel coupling so that when you turn off the engine the chipping flywheel continues to turn and slow down until stopped. I have not come across any other chippers with an overrun/freewheel before. Can anyone shed light on why Jensen fit this? Also, it is quite a while since I last changed the oil in the freewheel (due to low hours use, not neglect), that I cannot remember exactly what you do to drain the old oil out. I can't find anything online about it, does anybody have the answer? I seem to remember you have to position the freewheel correctly then undo some of the countersunk bolts on the front of it?
Mark’s life is a fairytale. After seventeen glasses of the merlot that cruise ships use to swab the jacuzzis, his engineering degree just vanishes.
11 hours ago, Mark Bolam said:
@Mike Hill may be able to help.
I’m not sure what you mean either.
Every chipper the flywheel continues to turn after you turn the engine off?
Some Jensens have a dog clutch which disengaged the cutting disc from the drive belts. My 340 had a dry dog clutch.
On stuff like wet ones the lowest hole is the drain and then rotate the same hole to 3 o'clock and fill to level. Confirm that's the case from catching the oil and refilling with the same amount.
Useful post.
