10 minutes ago, GarethM said:
They can contest use, as you have to prove you need it, for example agricultural wise you list what you might need to store equipment wise or I've X number of sheep etc.
Nope. The whole point of permitted development is that permission is not required because in principle the use is acceptable. The only requirement is "a written description of the proposed development, the materials to be used and a plan indicating the site". TCP (GPD)(England) Order 2015 Schedule 2 Part 6 E. The Council can contest the use only the way it can contest any other use of permitted development rights i.e. if it does not comply with the rights. But that is an enforcement issue, not a permission issue.
You don't need to prove you need it. Only if challenged. Of course the Council could take an application for determination as a tip-off of the proposed use, but it can't use that as a reason to withhold approval of the design aspects, that would be ultra vires. It can only force you to stop, but it can't stop you starting.
Having been through the agricultural, agricultural to industrial and domestic planning systems.
Even under agriculture they require a pretty in-depth amount of detail, including agricultural justification reports by outside people and even environmental.
I'm not saying forestry isn't easier, they'll make an example for that I can guarantee.
As far as I read it, and I am not looking to put any building / containers on land, but the buildings had to be for managing the land it is on - so what you need to look after the woods.
The was something about a fixed and a moveable structure - if you can move it then it is moveable (even if it is a 6" move) - foundations I think have to be like flag stones or similar. Dug foundations turns it into a permanent structure (not 100% on this one... the bloke who told me this has recently been evicted despite his moveable 'shed'). Container on flag stones OK, container on 2' deep concrete foundations not OK.
But I think in essence I have to ask, what do you need 6 containers for to manage a 10 acre wood? Double stacked with an office on top isn't for managing a wood. I'll assume 40' and not 20' containers? 1 off as a tool store - small tractor, hand tools, PPE and so on, 1 as a workshop and parts store (fencing and so on), and you might get away with 1 for toilet and so on... but probably the view would be 80' of containers so far toilet and facilities can go in one of them. What are the plans for the other 3 or 4?
Might be better looking at planning permission rather than skirting round the rules only to be told in a couple of years when you are set up that you've to clear the site and shut down whatever business you have going when the accommodation is removed.
Edited by Steven P
Oh great it's been another waste of time, as usual OP hasn't bothered his/her hole to reply or acknowledge help.
Can't be bothered with this any more. In future if  think I can help I will ask at least one supplementary question and if an OP doesn't reply then I'll assume they are a time-waster.
  • Like 8
It’s the entitled world we live in unfortunately.
we appreciate you though
  • Like 9
Its often the case when someone hears a response that they didnt want to hear. I get it frequently when people ask for a tree report and I recommend felling.
Fair approach. Maybe take a refundable deposit?
I always read your replies, there's a lot to learn, so the input is appreciated.
  • Like 7
Related, there are a couple of small fields up the hill just outside our village which sold a couple of years ago. One of them has a porta cabin on, the chap has been living in presumably with the eventual aim of getting planning, or maybe just that he couldn't afford a house but could afford a field.
Anyway, he started taking in green waste, fencing waste, bit of rubble which I guess is transit loads from here and there and makes a few quid. Not quite right but I was thinking at least that's stuff not being fly tipped on the fen somewhere.
Has now been arrested for taking in 100 tonnes of waste plastic, and starting to burn it. Illegal unregistered waste operation. Turns out he was a bit of a nutter.
