Husqvarna 545 dies when tilted either side or forward, but ONLY when hot
1d10t
Hello
This has me stumped, I have a husqvarna 545 that starts and runs great (starts 1 pull everytime after warm).
However, after getting hot (like after cutting down and trimming a pine tree, basically running hard for at least 5 minutes)
it will start to instantly die when tilted forward or sometimes even when tilted to either side. It happens instantly when tilted
and it still restarts 1 pull instantly afterwards. It happens with fuel and oil tanks full, so it's not the fuel pickup line (and the line
is not pinched in the tank, I checked). I tried spraying at various points with a brake cleaner after warming it up at home (but it wasn't hot),
at the gasket, side transfer ports, intake boot and even in oil tank, there was no hesitation.
Any ideas on what could be the cause?
Grab some spray carb cleaner, start it, tip it on its side to the point when it starts to die and with the narrow plastic straw fitted to the nozzle on the can, quickly give it a little spray in one of the cooling holes in the starter housing....towards the front, as far away from the carb intake as you can.....if the revs momentarily increase then its the crank seal failed. Quick and easy way to check
