New brakes screeching
eggsarascal
6 minutes ago, Doug Tait said:
Another possibility is a caliper not quite as free as it could be and isn't returning enough to fully release
That’s a good suggestion. Sticking sliders will cause a squeal, but those should’ve been noticeable when changing the pads? Interestingly, Brembo advise against copper grease on the backing plates and suggest squealing could be down to misalignment of the pads. Copper grease needs to be kept away from rubber seals and slide boots and it can cause them to deteriorate.
