cutting laurels?
Ducato64
I got some curved  shears from the japan amazon shop thats are very good on laurel etc.
There like loppers  that mated with shears & sit between in the function they do.
You can got at it hacking back chunky stuff rapidly witht them once you get your eye in but there  not  very good on the fine stems like at the end of the video.
Sometimes use a 18v makita cordless topper for thicker stuff also
I use loopers on mine (ratcheting anvil type) for heavy stuff and just a boggo electric hedge trimmer for general tidy.  Used to use secateurs but for the difference in time I can put up with some sliced leaves!  The hedge trimmer is no match for woody bits but if done regularly (e.g. annually) that is not a problem.  Although clearly I do not always manage that, hence the use of loppers!
Don't know if the OP is commercial or a home owner so unclear what best would be in his case.  (I'm home owner)
