A small update, I put the original cyl and piston back on as the replacement needs some minor fettling that I dont have time for right now.
I did find time to do the .325 chain. I decided to lengthen it as suggested by somone on here, 78DL needed for the cheap 20" bar. Enlarged the bar slot and new oil holes. However, the bar is slightly narrower than the saw mountings which is a problem, it means the chain can pinch when tightening the case up. I had to modify the shim plate and put a 45 degree chamfer on the bar mount surfaces for clearance. Seems ok now tho I havent run or cut with it yet.
At ~£3 per chain it will be worth the effort if it works.
  • 5 weeks later...
Saw is running great, including the cheap chains. One annoyance it has an open exhaust with no baffle/spark arrester or anything like that. I find the exhaust heat is burning the wood and on connifer, painful to breath !
Is the proper 372XP exhaust different? Maybe I should get a genuine one or add a baffle.
Thanks
Mark.
My genuine 372xt occasionally chars the bark or sets it smouldering, never really been a problem, not burnt anything down yet.
Thanks
Mark.
What is the chains you're using, got a link?
Edited by scbk
Or just save the hassle
WWW.AMAZON.CO.UK
Shop Oregon 21LPX078E Type 21 LPX Chain, 78 Drive Links- Super 20 Chisel Chain .325 1. Free delivery on eligible...
ROTATECHPRODUCTS.COM
Unlock the true power of your TIMBERPRO CS6150 chainsaw with the 20" Rotatech Chainsaw Chain! This high-performance...
WWW.EBAY.CO.UK
OREGON TYPE 21 chainsaw chain 78 DRIVE LINKS .325" pitch 0.58" gauge 21LPX CHAIN. Condition is New...
