Kubota cylinder head
bolla
I have an En Tec wood chipper I think En Tec became Timberwolf
My chipper has a Diesel Kubota engine V1200Nd stamped on the engine and a sticker on the cylinder head cover V1205.
The Engine recently overheated due to a clogged radiator, I have replaced the radiator and a new fan but am sure the head gasket is blown as getting air bubbles in the coolant, I want to take the head off at the weekend but if the head is cracked I cant find any replacement heads available in this country.
Any advice on changing the head gasket or if head is cracked any where to get a new or refurbished cylinder head
Will it be ok to reuse the cylinder head bolts
Thanks
I'd get the head off and see, that age should be old school cast iron head I would have thought - not that likely to distort on overheat. In the old days we'd just clean up, new head gasket, bolt it back on and see how it goes. Unless it proper overheated and melted the pistons of course....
