Timberwolf TW160 cut out
Mark Bolam
1 hour ago, Con said:
No experience on 160, but sounds electrical. Fuse is a good shout. If low oil cut off has activated, I'd of thought there would be some sort of reset procedure. Topping up or changing oil probably won't do it
You’re right Con, but I can’t find out what the reset procedure is!
I’ll try and check that fuse later today or tomorrow.
From a brief Google the oil sensor is fitted like an injector, it's a circular black plastic thing with two wire bullet connectors.
A few other searches also showed a metal box which I presume is a relay, same couple of wire arrangement with bullet connectors.
The timberwolf manual was a bit poor if I'm being honest, B-R-1.0 might be a black and red wire to the engine kill splice.
Dumb afterthought, is this old school Honda without electronicals?.
Edited by GarethM
