Iveco Daily issue
Ty Korrigan
Weird one this.
Put it into reverse and the engine cuts out, all power including lights.
Unplug reversing sensor, no issue except it won't pass the 'control technique' (MOT)
Bought a new sensor, worse, reverse lights on all the time.
Change plug, no change.
What is likely to be the issue here?
    Stuart
28 minutes ago, Ty Korrigan said:
Weird one this.
    Stuart
What fault codes have you got?
13 minutes ago, eggsarascal said:
Without diagnostics we will all be guessing, OBD11 readers for basic stuff are fairly cheap. You
I agree in principle, however iveco can be hard to get any sense out of with a basic code reader. Especially for such a weird problem.
I’d be looking at system voltages when reverse engaged. A major voltage drop could cause the system to shut down. You could look at the reverse lights also, possibly a short here (although you’d expect a fuse to pop)
is it @Rac man who’s a bit of a whizz on iveco?
My mechanics code reader wouldn’t fit/work with my 2007 daily - he had to borrow a specialist one.
id be looking at earth connections first and as doobin, wrote above, a short somewhere. Italian electrics can be a real head scratcher even for an experienced auto electrician
