If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
WeleaseWoderwick
Good evening,
I would really appreciate some advice about taking out a Cypress near to a house. I'll explaint the situation and what I know of the soil conditions and history and I have one or two photos.
We're buying a house. It's a fairly typical 1930s semi detached. We will be doing the usual kitchen extension. In the back garden within 6.5m of the house there is a mature Cypress tree. I think it is probably a Leylandi, which I also think is quite a high water demand tree. When we do the extension this tree will be sitting in the patio and dropping needles and cones all over the dining area plus blocking all the light into the back of the house. God knows why the little old lady who lived here prior planted it. Anyway whether the tree is coming out or not is irrelevent. It is coming out. The question is 'how?'
We are on good terms with our new neighbours. The tree overhangs their boundary and they are keen to see it go. They have an extension already, built first in 2001 and then when they moved in they demolished it and built a new extension on top of the existing foundations. The tree is within around 3m of their extension. They had agreed its removal last year because it was dropping all over their patio, but the little old lady bottled it at the last minute and in the end they agreed to crown it and lopped off every single bough overhanging the fence line. It is now about 10-15m tall and lopsided. I would estimate they've reduced it by >60% already.
Neither of the buildings have any evidence of subsidence or cracking. They are rendered, so if we had the typical step-like cracks it would be pretty obvious. These houses are all built on concrete raft foundations, and that is a consequence of the local ground conditions that I'll explain now.
The site is basically an old quarry that was excavated for gravel in the 1920s and then backfilled with industrial waste - rubble basically. The old Bank of England is down there somewhere, apparently. There is a layer of topsoil, which I estimate extends downwards for 1m before the rubble layer which goes all the way down as far as I know to the London Clay layer 9m below the surface. We have drains around 6m from the tree, and they have rubble in them so they have obviously been breached, presumably by roots. This implies the roots stretch 6m or so and are reasonably shallow. 1-2m deep max.
Here is a photograph:
My question is simply can we take this straight out or are we into reducing it further? When is the optimum time to do it? The schools of thought I've read online are:
1) Reduce it by 25% per year until it's < 30% of origial size and then take it out
2) Doing the above exacerbates soil recovery time so best just to crack on and wait 2 seasons before building
3) If there is no evidence of subsidence already then the tree can go, but best to wait until maximum soil dryness in late summer / early autumn to minimise any swelling problems (clay assumed).
We have not done any soil or ground investigations, but did talk to a groundsman at a nearby property on the same estate who was installing a sex pond / jacuzzi, he had exposed the rubble layer and said the topsoil was loamy.
Looking forward to any advice you guys can give. Hope that's enough information and not TLDR.
Thank you!
10 answers to this question
Register a new accountSign in
