15 minutes ago, Dan Maynard said:
Which Bandit, so is it a petrol or diesel engine? I've got stuck in the back of my head that high exhaust temperature can be an indicator of lean running, if it's petrol, so I'd pop the plugs out and see what they tell you now.
If you had it serviced they might have put new ones in anyway but I think you'll quickly see evidence if they are overheating.
Yes it’s a kohler 25hp petrol engine
yeah had new spark plugs
17 minutes ago, AHPP said:
I sent NGK a picture of a strikingly green plug I found recently in case they wanted it for that page. Rudey poos didn’t even reply.
Maybe they thought you'd made it for views on the 'gram.
Should have replied at least though.
Retarded timing...
This means that the charge is still in the process of burning when it exits the cylinder, thus giving rise to very high exhaust gas temperatures..
john..
Do a plug " chop " to get the exact reading . Run flat out for a few seconds then cut the ignition without closing the throttle .
18 hours ago, john87 said:
Retarded timing...
john..
An interesting comment. You could possibly put a mark on the ignition flywheel and strobe it to see if you get any form of advance and retard when the engine is revved....assuming the engine has some sort of advance/retard device or mechanism.
