Husqvarna T540 MK III guide bar & chain recommendations please ๐Ÿ™
Could T540 Mk IIIย
OWNERS recommend me a good guide bar for this chanisaw model?ย
Also which size it's best for climbing most of the time 12" or 14" ?
It came with Husqvarna 14" standard bar.
Got already echo 2511 with 10" mini panther bar forย  pruning.
ย
Any advice much appreciated ๐Ÿ™‚
ย
Sorry Iโ€™m no climber, however all the mk1 and mk2 machines I see are on 10 and 12โ€ bardoโ€™s, do not see many on 14โ€.
Thank you buddy, yeah 14" it's more for removals or people's who like longer bars, not sure how it's effecting the balance hence I have asked for opinions.
ย
Donโ€™t know the new t540 as my mk1 fell apart and husky refused to repair or replace it under warranty so not had one since! However Iโ€™ve always found a shorter bar better to climb with, once you get to big for a 12โ€ bar itโ€™s up with a back handle for me.ย
Guess it's also a question of what trees you're doing, and what back handle to move up to. I usually strip out with battery saw, then have a 14" on my 201 to start chogging with, next step 20" on MS400 usually.ย
ย
I know someone who likes 12" bar on a 200, next saw then is 16" on a 550 for any chogging but might need to swap big saws again before reaching the ground.
Edited by Dan Maynard
Used 14" today and it was brilliant, weight balanced very well, i think If I get lightweight 12 inch bar that weight balance might change so I will stick to 14ย
I have the Busy T540xp Mk 2 and I have also recently picked up a Mk 3 as well.
I run 14" bars on it and I feel comfortable with that set up and really like this top handle..
They say that it will take a 16" bar and I don't doubt it. But I then swap out to a 550xp with an 18" bar on it.
A 10" or 12" is a bit small in my opinion... I would rather run the echo 2511 on a 12" bar..
  • 5 months later...
Weโ€™ve ran T540s since the mk1,
i prefer 14 inch and ย some prefer the 12 inch bar.
husky bars arenโ€™t great and of late , Oregon not any better..
Sugahari very good.
I recently got a mk3 , really like it , lots of torque.
only negative is it doesnโ€™t go long on a tank of fuel.
anybody else noticed same ?
thanks.
I have a MK 1.5 ( a Mk 1 with a lot of the MK 2 bits on it )ย  The Husqvarna bar that came with it when I bought it back when they first came out de railed the chain within the first few cuts . On closer inspection the bar was de laminating . Used a Sugi light weight pro bar since then and it has been fine . ย
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
