1 hour ago, Elliott.F said:
Mostly cutting up to around 16” with the occasional larger tree, coppicing, all the processing of those trees and firewood.
I think I’d prefer a longer bar for doing my firewood, say 24”, but I’m guessing I’d need some thing around 70cc to run that.
It looks like 50/60cc with 18” bar would be the compromise.
If you can find a good Husqvarna 362xp it will take a 24inch bar in
.325 Rob D supplied mine, you could also run 18 and 15 on that saw. But it's just a matter of finding one.
For a all rounder  50cc with 15in bar.
But if limited to  one saw only a 60cc with 18 in will cover more stuff.
Think you need 2 saws - handy if you get the bar trapped to have spare one with you or if one stops working, and hazel to large  trees is a big range.
What saw do you use atm?
It depends what you're mostly cutting. My go to saws are a 550 with a 15inch bar and a 572 with a 24inch bar and that covers 95% of what I cut.
4 hours ago, cornishman07 said:
Trick question, you need three saws minimum, plus a few back ups just in case anything happens to the first three!
There speaks a man who knows how to justify another bought saw to the missus through experience
The one saw I always took when starting was a 60cc and 18". It was about as heavy as I wanted to use all day long and could do all I needed.
Sometimes, if there was something too big, I'd go get a larger saw or leave it and do all the bigger saw jobs in one hit, when, everything else was sorted.
I have taken one power head and a couple of bars/chains, then switch them if required.
Yeah I’m thinking 4 saws to cover all the bases, then at least one back up for each saw, that makes 8 saws, then a couple of spares to round it up to 10 saws. That should just about be enough.
Pretty much what I use, but the bigger saw is a 660 with a 25.
550 wherever possible though, it’s so light and snappy.
If we’re into a lot of heavier stuff the 500 and 462 get through a fair bit of work, running 20”.
Get two work vehicles the you can double it, each truck needs a set 😎
