28 minutes ago, Ty Korrigan said:
I transpires, all these Efi running issues are down to a batch of faulty bonnet catch sensors right?
I think Jase's reticence points to a fundamental flaw in Greenmech's installation rather than a problem with those state of art B&S masterpieces of engineering 😉
Edited by openspaceman
I'll not sleep properly until Jase tells us.
 I told you all I was scarred by the whole Efi episode, well I actually had a nightmare this week.
I dreamed I was on a job in town and the Evo suddenly went haywire.
When I opened the bonnet up, inside was a Vanguard Efi.
I was terrified!
Then people from my memories, dealers, mechanics, clients, other arb guys, friends, Greenmech haters kept coming up to me laughing and pointing.
I was naked but for a T'shirt and a pair of boots.
Edited by Ty Korrigan
  • Haha 7
16 hours ago, paddyvero said:
Mine turned out to be a bad ground and loose engine mounts. Fixed in a jiffy and back to work. They even washed it for me.
Phew!
Same engine?
Similar symptoms?
Certainly similar, mine would rev all the way back up to full then die back to idle, might run at full pelt for5secs, 30secs, or a few minutes. Dealer mechanic said it was sparking at the engine mounts.
Mine had its high pressure fuel pump changed twice which cured the hot starting issues.
This video is a very different problem as it  started fine.
How could a bad earth provoke these symptoms and can this be demonstrated by creating a bad earth to prove it?
@Jase hutch
1 hour ago, Jase hutch said:
Sorry to blow your theory of out the water Mr Korrigan but on all GreenMech chippers , the battery earth lead goes directly to the engine.
Check yours and you'll see..👍
Not my theory Jase but one punted above by the dealer of paddyvero.
I could see through this lie but wanted a response.
Chipper dealers, more spin than a Conservative party dealing with a threesome sex scandal.
