3 minutes ago, JDon said:
I'll post them all tonight then. Where should i post them?
Start a new topic of your own if you've a few mate, or stick them up in "today's job" or "at work today" threads.
3 hours ago, dumper said:
Don’t send them post them.  Please
Posted my own thread cheers
To the topic, I would look at a small stove downstairs if you can rather than trying to fit a back boiler to your existing system - might be cheapest option if possible even with chimneys and so on.
Next thought would be warm air ducting from the stove - as above if you can manage it. Look to air source heat pump air systems for fancy control systems you might be able to put together.
Reading this thread I thought to myself there must be something on the market regarding heat exchangers and log burners ,so googled it and products at www.recoheat.co.uk seems like they could do the job ,from what little i read on there site it seems cheap and a possible solution?might be worth a click?
Just a note but surprised you found a back boiler stove being advertised - as of 2022 all stoves must now meet stringent particulate matter emission levels - as boiler stoves reduce the burn temperature / increase particulate matter they are in effect now band in the uk and it is illegal to fit one! As a stove fitter I'm pretty sure on this but happy to be corrected if I'm wrong
Boot
Boot
What about repair?
