15 minutes ago, AJStrees said:
Well could be WRC would have to see scales or what have you. Or is it crypto japo?
Pics are a bit blurry until you click on them but stupidly, didn't get one. I can confirm though that it had pea sized cones
If in doubt, crush some green stuff between your fingers, pineapple sweetness=WRC/thuja
Bitter=Lawson
Looks like a variegated Lawson to me.
Edited by Mick Dempsey
Bitter=Lawson
I always think of Lawson as sweet like Turkish delight
On 28/02/2023 at 16:54, Clutchy said:
I always struggle to tell the difference, any ideas? My gut is normally Lawson.
Any tips on differentiating?
Absolutely, it's a cinch. You need to look at the foliage - they are completely different. OK, you could confuse them but once you've seen them both side by side you will wonder how you ever got them confused. However, not always present, look first for cones as that is even easier. Lawson's are small globular; WRC are more cylindrical typically open at the top. No cones, go onto the foliage. WRC are both flattened branch structure but also flattened twigs. Look at the smaller leaflets - they are only on one side pointing towards the branch tip.About Western Red Cedar - Tree Identification, Properties & Uses - Softwood  Species | naturally:wood
Lawson cypress. Not like that! Whilst the youngest leaves all appear on one side, further back there are more both ways. Leaflets not so obviously flattened. If the branching structure is not flat/planar then you are dealing with Leylandii (with less chance of cones).
Chamaecyparis lawsoniana 'Westermannii' / Westermann's Lawson cypress  | Conifer Trinomial | American Conifer Society
And remember Lawson's come in a whole variety of cultivars - some small, some large, some with only juvenile foliage, some with both. It's a highly variable mess but you shouldn't get any of them confused with WRC!
  • Like 7
I won't mix them up again 😄
Thanks for the tips
