Hi,
my Timberwolf 150 radiator sprung a leak today. So brought it home before using it and doing any damage.
I understand most company’s can recore the existing radiator for £150-£200 ish.
Alternatively I spotted an aftermarket Ali radiator for sale on eBay for £450.
Wondering if anyone has experience using this one or should I go ahead and repair the original. What’s drawing me to the newer one is it’s all aluminium…. No plastic top and bottom sections.
any help/advice appreciated.
Thanks Connor
Can you recore a plastic radiator? I had an 2002 150’s recored but they made them out of decent stuff back then and was told they could not of done it if it was a newer machine.
Ahhh ok thank you. Just going from a quick conversation on the phone to a radiator repair company.
If that’s the case may just bite the bullet on the aluminium one, as new ones from the likes of spectrum plant are again plastic.
thanks for the replies!
connor
  On 16/02/2023 at 21:29, monkeybusiness said:
Google Wrexham Radiators - they will see you right (if it can be fixed they will fix it, if it can’t they’ll supply you one at the right money). Wonderful people!
Expand
I’m afraid I have already ordered that one from eBay
thank you for the kind suggestion though!
Will keep them in mind if Im needing one again.
thanks
Read more
