3 hours ago, GarethM said:
What about some torx button flange head screws/bolts instead of self tapping screws.
Just thinking the self tappers might turn into something of a bed of nails, unless you're going to grind them flat on the reverse side ?.
I have used tek sticther screws to give a bit of purchase on a steel sheet, no reason they wouldn't work on aluminium.
WWW.FASTCO.CO.UK
7.8 x 25mm Mega Stitcher Self Drilling Tek Screw With 16mm Bonded Washer Pack of 100
a 16mm self tapper won't come close to being any trouble on the underside, the ramps are probably about 120mm deep in total
5 hours ago, Stere said:
How about  (cut  to size) the   rubber matting they use of horse box ramps etc
Best way as no strength loss by drilling holes.
Or runs of weld
