Thanks all. I was thinking I'd dig them out or winch them out, that's about the only option. But I will look into wide tracked stump grinders. The young trees trees are being cleared to open up a patch of heathland for conservation. Thanks
16 hours ago, david_T_Nairn said:
Is it sufficient to just dig out the main stump and to cut the roots say, 30cm below the ground? Or do I need to dig out ALL of the root to prevent regrowth?
Yes, it is sufficient to dig out the main stump. I doubt you'll find all that much below 20cm, and it won't regrow from the roots down there anyway.
A bit of bare ground  will be good for heather to recolonise as long as any arisings are taken off site to reduce fertility.
1 hour ago, Dan Maynard said:
If it's for conservation they may not want the plastic bits left over.
Tip the granules out of an eco plug and seal over with beeswax.
if you go to that trouble just put ammonium sulfamate granules into the hole and whittle a stick to plug it. Far more eco friendly than glyphosate
