SAWDUST - COMPLIANCE
1 hour ago, Jessica Envirovue said:
Hi all.  I am looking at a compliant solution for fine sawdust (5-10 tonnes/week, bagged in static free bagging). It cannot be used for biomass as it can cause dust explosions. We are needing a licensed carrier and end destination. We are based in Essex area. Thanks in advance.
I assume you mean a compliant solution for disposal?  In which case perhaps you could specify what the sawdust comprises of?  For instance is it only pure wood dust or is it also man made boards like MDF, plywood etc?
3 hours ago, trigger_andy said:
Good luck disposing 5-10 tons a week though.
That's a lorry load of aubergine next to a lorry load of flowers, you could tip 5 ton a week of sawdust here and they wouldn't hardly notice - as long as it's clean.
Edited by Dan Maynard
  • Sad 1
I don't like aubergine, but there's some nice looking courgettes and squashes in there :mellow:
It will be a combination of pure wood and man-made wood such as mdf and ply board.
It is extracted mechanically via a Nederman dust extraction system from the wood fuel prior to being dispensed into the boiler for burning.
The wood is Grade C non-hazardous could be suitable for briquettes? But may not be suitable for animal bedding, although I’m not experienced in how animal bedding is derived from wood dust so couldn’t be sure of restrictions in that sense.
Edited by Jessica Envirovue
