Do any of you dry logs in containers made of Weldmesh Panels?
cessna
25 minutes ago, Stubby said:
Isn't that just a " pile " with Herras fencing round it ?
Yes and it will be bulging all kind of shapes by the time it's half full, when I stored logs that way I used plenty of clips on each corner and still had to lash lorry straps around it try to keep it in shape.
There are scaffold poles driven down the sides for support, which also support a scaffold tin roof easily once filled.
Method in the madness 😉
Edited by doobin
Even though you have put the mesh on the inside it will still breakaway from the frame causing it to go out of shape.
It works just fine for a cheap bulk log store.
mind you, it was better when panels were a tenner not £35 each!!!
  • 1 month later...
