Where would i get a copy of the "rules" I suppose they are rooted in common sense and would be something to work towards??
Having said that, whilst i do not have two ropes, i always make sure i am tied in by more than one means unless i am actually going up or down, so would that count anyway??
john..
john..
Hi John,
"The rules" are detailed here https://www.trees.org.uk/News-Blog/Latest-News/Tree-work-at-height-–-Regulations-and-guidance
Your method of work (climbing) would not meet the rules I'm afraid as, almost without exception, you need to have two separate systems at all times, ideally attached to two independent anchors.
ATB
Paul
38 minutes ago, AA Teccie (Paul) said:
Hi John,
ATB
Paul
Paul,
1. What is the legal status of the guidance in that link?
2. When was the last time you climbed a tree?
Don't answer with anything else.
Edited by AHPP
22 minutes ago, AA Teccie (Paul) said:
Hi John,
ATB
Paul
Ok, now i am no expert here VERY VERY far from it, but would not two separate systems attached to the SAME anchor, be plain stupid and pointless???
I cannot see it would acheive anything.. For one thing, i would think the weakest link would be the tree itself, the rope etc being strong enough to simply pull the tree over or break it in most cases i would think...
Ok, it might help if you were to touch the rope suspending you with the saw, but i would imagine if you did that you would cut two [four??] ropes just as easily???
john..
31 minutes ago, AHPP said:
Paul,
1. Industry guidance - has no direct legal status, that is contained in the Work at Height Regulations (but it is guidance endorsed by HSE, the workplace regulator.)
2. Some time ago.
Not sure 'what else' I might have answered with.
Paul
john..
Two independent anchors should be used wherever possible, which is likely to be in most cases, but the guidance does allow for a shared anchor where 2 separate ones aren't available, i.e. the exception - two systems (primary & backup) on a suitable shared anchor is still deemed to be safer than a single system.
Not if you are chogging down a single stem.
