550 XP on the spot buy..
3 minutes ago, spudulike said:
They fitted it on the 357XP and it was an abomination!!!!
Good for your business mind.
Mine seems fine... 😆
@ the OP: I recommend the narrow kerf .325 setup when you come to replace your bar. Much quicker cutting compared to standard
52 minutes ago, Stubby said:
Is it actually no decomp  ( like the early 346xp ) or is it an auto decomp ?
No Stubby the deco valve has completely gone, this aids hot re starting, plus there is always some leakage at the Valve
17 hours ago, adw said:
Don’t shoot me, but the auto deco valve worked well on the 335/338xpt
What is it with Husqvarna and top handles.....everyone knows the MS200T is king........time to retire to the bunker;).........discus between yourselves. First on the agenda, which saw picks up best when you give it some throttle after hitting the wood:thumbup:
Give me a T540 any day, at least the muffler doesn't fall to bits, and whoever designed the throttle rod system wants shooting, each one to his own.
19 hours ago, Steven1210 said:
Is that an 18" on it Jamie?
Yes it is an 18" bar on a 550xp mk2. It also has the Husqvarna Tool Strop Attachment on the handle as well,  I got it mainly for when I am up in a tree on a rope and harness... I was so impresses with a mates 550xp mk1 with its lightness and power.
So it is the first saw to turn to after a top handle before using a much heavier chainsaw..
