reversing chain bar..
john87
I flip the bar every time a chain comes off. If I forget to, it makes less of a difference than if I forget to at chain replacement time. Inspecting and dressing rails more important than flipping on the numbers I’d say.
Hi All,
Although i have used other peoples saws for many years, it is only for the last few years that i have had my own. I have checked the bar and there are no burrs or sharp edges or sloppy grooves, so good to go?? Would i be right in thinking that if you always make sure the things are full of chain oil and use decent oil, the bars will last for a very long time??
john..
3 hours ago, john87 said:
Hi All,
john..
Doing what you say will extend the life of the bar over not doing it . The lenght of time it will last is dependent  on the amount of usage . Piece of string and all that . It is regarded as a consumable .
Edited by Stubby
19 minutes ago, sime42 said:
Also depends how much the saw has been pushed on whilst cutting. Obviously if the chain is kept sharp there shouldn't really be too much pushing/forcing the bar through.
I always keep the chain well sharp, as, like all cutting tools, a little sharpen often, and they last loads longer than waiting until thye are blunt and then grinding/filing a load off so it more or less feeds itself into the cut..
john..
