If a driver has the so called grandfather rights they can drove a 7.5t vehicle with a 750kg trailer.
If you wanted to increase that trailer weight to the full 3,500kg can you just take the +e test for that class or would you first have to complete a C1 initially?
C1 E Is on my licence and I've never taken any extra test
As above, you should have C1 and C1E from grandfather rights with note 107 applied to C1E limiting the gross train weight ("combined MAM") to 8,250kg, which will limit the trailer weight as you say. You'd need to take C1E to raise this, but I'm afraid I don't know for sure if you can go straight to this. I don't see why not though since your C1 is no different to anyone else's, i.e., it isn't restricted in any way.
Edited by Treewolf
Just found this in DVLA leaflet INF30 "Requirements for
towing trailers in Great Britain":
"If you have subcategory C1E (107) on your driving
licence and wish to drive a vehicle and trailer with a
combined weight of up to 12 tonnes you can apply
for provisional subcategory C1+E to take the test. You
do not need to get subcategory C1 first, but you have
to meet higher medical standards and pass both the
category C theory test and the subcategory C1+E
practical test."
YES, after passing medical & theory / hazard tests.
Or they can drive a 5000kg vehicle with a trailer plated to 3250kg.
Edited by Justme
But it also has a 107 code restricting you to a gtw of 8250kg
Mine has not got 107 anywhere on it .
