Β Hi Steve hows things all good I hope ,so mullberry is a bugger to dry then ,stunning colour got 8 boards out of the small bit I got a much bigger bit for tomorrow or Friday should get 12/14 inch wide boards from it.
Should seal all your end grain as soon as you get your logs mark. I use SBR personally but pva 50/50 is just as good and stops the end grain from spilling and reduces shrinkingΒ
Edited by topchippyles
5 hours ago, gobbypunk said:
Thanks guys will get the pva out what about borax just mix up and paint on all over
2/3 coats each end mark but its a lot easier to paint the end of the logs before they are milled. First thing you should be doing when they get delivered to be honestΒ
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
