Hola, got a new bus and the linkage arms are alot shorter than before
When putting the igland on her I've cut down the shaft to fit but I can't help but slightly wince at the shaft angles
Does anyone one else do anything to mitigate this?
Offset the winch on the linkage arms when onsite etc? I've done a fair bit of searching online and can't find any obvious examples of this
Also had to cut away most of the pto guarding for clearance where it fouls the drum casing, anyone got any ideas to help this?
Cheers
