Sign in to follow this
Ds Tree services
BR600 Help
Probably worth clearing the hole in the small end if you can and then getting the diameter of that hole, the diameter of the gudgeon pin and the distance between the inner flats of the piston where the bush fits in to and get one made and then push it in to the small end hole with a bit of bearing lock fluid - you could possibly use heat and cold but go easy on heating the con rod too much.
It may last well and worth it compared to the costs you mention.
Share this post
Link to post
I used to have a Renault Gordini  when I was an apprentice  back in 1807 .  I turned up some small end bushes for it from fozzy bronze . Worked a treat !  👍
Edited by Stubby
Share this post
Link to post
1807!!! 🤣🤣🤣 Gem!
Share this post
Link to post
Just now, Ratman said:
1807!!! 🤣🤣🤣 Gem!
Well you know what I mean bud .
Share this post
Link to post
3 hours ago, Ds Tree services said:
Yer spud you would normally have a needle bearing but this has a bush ? why maybe as its 4mix..??
Spoken to my local dealer and they are saying you need to buy the full new crank and con rod its £280 then £90 for the piston and £30 for the seals and other bits a new machine is £460...
The only bit that failed was the top end bearing and the piston was slightley damaged. Looks like i will hafto keep an eye out on ebay..
Don't bother putting parts in it, the cost as you say is pretty horrendous, especially as Stihl do a whole replacement engine for them and at fraction of the cost.   I have one in at the moment which has done exactly the same thing as yours, a very badly seized small end.
Share this post
Link to post
Are you just putting a new engine in? if so do L&S sell them? Out of all the tools i use the blower was the las thing i though would go...lol
Share this post
Link to post
Haven't seen the short engines on L&S.  I was surprised to see it listed in the Stihl parts list, but I need to double check it was a BR600. I'll do this when I go into work tomorrow.  The price was a no brainer though compared to putting parts in it.
Some say this fault is down to the nozzle waring and it putting excessive load on the engine making it run extra hot.  The one I have in the workshop has hardly been used.  It was seized absolutely solid and only because of the small end.
Share this post
Link to post
Never had this issue before but I can't help but think.... Why faff about putting a new engine in a tool that only costs 400.00 and used every day?
When mine started dicking about I just bought a new one and threw the old on a shelf
Share this post
Link to post
Stihl and replacement parts prices are something else! Once upon a time, I broke the casting on my Kombi pole saw attachment.
" Allegedly", only me and a bloke in Scotland had ever done so. I was quoted something like £175 for the casting only, by the parts department.
Over in the Sales dept, I purchased a whole new attachment, ie shaft, casting, bar and chain, for:
£160.00 You couldn't make it up.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
