If you went to the ARB Show 2023 last week there is a good chance you might have seen the popular GL&D range of Hydrostatic Tracked Bio Chippers which both Chip and Shred which are part of their range of Towable and Tractor Mounted Woodchippers which are exclusively distributed by AMIA in the UK and Ireland.  GL&D are an Italian manufacturer.  If you would like to speak to one of our customers send us a message and we can pass details on for you.  We have 2 of the models on show were the GL&D SUPER Hydrostatic Traked Bio Chipper which has a 22hp Honda Engine and Chips/Shreds over 5.5" featuring a large Feed Roller and No Stress System which is 95cm wide with more information below:
WWW.AGRIMARKETIA.COM
GL&D SUPER Hydrostatic Tracked Bio Woodchipper is a market leading Bio Chipper which shreds & chips up to 5"...
We also had the GL&D 'T' Hydrostatic Tracked Bio Chippers which have a 21hp Honda Engine and Chip & Shred around 4.2" featuring a unique feed drum design which helps to pull the material into the chipper.  This model fits through Garden Gateways with ease as it is only 75cm wide.  You can find more information about it on our website here -
GL&D Titan Tracked Bio woodchipper is a compact machine capable of going through garden gateways. Shred green...
Finally we also had the GL&D Hydrostatic Wheeled Bio Chipper on the stand which also features the Honda Engines with the same performance as the GL&D 'T' but on powered wheels instead of tracks.  More information here -
The GL&D HYDROSTATIC Wheeled Bio Woodchipper is equipped with a special rotor that makes it ideal for the...
Edited by AMIA Machinery
  • 4 weeks later...
16 hours ago, shillo said:
this one in particular, GL&D Hydrostatic Wheeled Bio Chipper
To me it looks like the hopper narrows in at the sides a lot, wouldn't want to do a cherry with that.
I've not seen one though, didn't make the show.
I could never see that mixed rotor idea being one or tother! I can remember the old A Plant depot in Abergavenny having them in another make. If the customer had dirty stuff, the blades would be removed. If the user had timber then the flails just absorbed horse power.
We have a nice used 2021 GreenMech CS100 18hp in stock for sale, condition you would describe as ex demonstration. Brand new blades, new infeed curtains, manufacturers warranty. £3,995 + VAT. Can be pallet shipped anywhere in the UK.
Any Jo Beau M300 users recommend a specific grease for the bearings or other maintenance tips? I've found the blades torque setting at 60Nm through the search but not much else. The Netherlands manual I've found online seems a bit light on specifics of oils and lubes but might just be my language skills.
I've got an M500 which might have the same bearings, I got an English manual by asking Global Recycling while I was ordering some parts.
It is very light on detail though. Mine didn't have a working hour clock when I got it, since the drum bearings went I put one on, so now I check belts, grease bearings, change oil every 50 hours. Filter change 100 hours. The bearings are sealed so I don't want to over grease them.
You can also find a Honda engine manual fairly easily, they suggest oil change 100 hours or 6 months but I don't do 100 hours in 6 months so compromise, trying to remember every 6 months doesn't work for me.
Edit: so far 220 hours on this regime so it's not an immediate disaster, time will tell how much more I get out of the bearings.
Edited by Dan Maynard
