59 minutes ago, dan494 said:
What's the price of the 18hp one thesedays then as was only a few hundred more than that?
List price of the 18hp is £4,730 plus vat.
  • 1 month later...
  • 3 weeks later...
2 hours ago, Nikos Papadopoulos said:
What size of a chip does your machine produce ?
Can the size be homogeneous ?
Does the chip size has variables that it depends upon, such as type of wood, dry,soft etc ?
Not sure if you meant in general.... This is for our machines.
Shreds will deviate in size, from 1 x 1 cm to 2 x 3 cm. However, the thickness is evenly around 3 mm. I tested wood chips in my own wood-burning stove and the heat that was generated was amazing. You will have to use a modern wood stove with an efficiency of over 90%, otherwise the consumption is too high.
Here's a picture of the chips.
Or have a look at my Instagram 'haeckslercompany'
You will find a short video with chips, 2nd in line or so.
Have a nice weekend
How do you dry/season the chips before you use them?  I have a JB300 and a 25KW biomass boiler for my home setup but if I can use my woodchips in the boiler (and internal 5KW stove of high efficiency) before my wife uses them for top dressing the flower beds, I'm all ears!
On 18/07/2019 at 20:58, Josh u a Tree said:
Sure 4k is a lot of money, but still just the equivalent of about two big chain saws.
In my days in tree care I was pretty prudent before investing as well, but buying a good small chipper really saved me a lot of time and effort.
You must be joking. Surely you mean four or five or six big chainsaws?
Last time I looked, you could pay brochure price of a couple of grand for a big saw! Our Loncin engined CS80 is £3,600 odd pounds!
I've staved off buying a wee chipper for a long time,
Won't be able to for much longer. But what I don't get is a Hyundai/Rock 14hp 4" is about £1500, whereas the cs80/100/m300/m400 etc is 3-4 times the price.
I've used the cs100 on various occasions and it's a solid bit of kit which holds a decent resale price.
Just can't understand why they are so expensive?
