The early fuel tap was buried under the fuel tank with a steel wire extension piece for operation. The later type was mounted externally and easily visible.
I wouldn't worry, if it's been running ok and the engine oil level hasn't been rising then it'll be fine...
On 24/03/2018 at 19:58, PeteB said:
Of course you can join the club Baz, all makes welcome....Good to know that while Peruzzo copied GreenMech - at least they made a complete hash of the finer points like manuals etc.
The peruzzo manual is deffently not a fine piece of literature ? the tracked side of it that we brought it for has redeemed it for the lack of reading material (until I need said book, than I may be somewhat frustrated) ?
Hi Will C I will pass your comments on about literature to the Peruzzo Management to see if things can be improved, they are quite proactive like that as a manufacturer. Just on Greenmech website now, still can't see a tracked version....
Heh Pete B you have got the wrong end of the stick, the machine that Bazoo refers to is not the Peruzzo TB100-C but the one that is in the hyperlink. This is a Geotech Product sold through Agri-euro directly from Italy. Have a look again and press the "these".
2 hours ago, inthewoods said:
Just saying...
Nice work! If it was the Original and the best, a GreenMech, it would have still gone through but without the exhaust fumes filling the place! Just saying...
No little tracked one, why didn't they just copy our manuals, they did everything else! I even saw a copy of one of our tech drawings on one website!
Because that would be taking the p..s
It was nice work, made easier with a fantastic machine! Which is an original, an original Peruzzo! If you were talking about forst I could understand your bravado but it's not a GreenMech mate - it's better!
Would you want to push a cs100 where I take my peruzzo?! On your own that is or have to pay more in wages for extra manpower and become less competitive...
Aspen fuel was used in the 'dumper' engine btw, so put that in your pipe n scmoke it! ? ???
