Echo cs2511tes with panther bar 12 or 14 inch?
Hi guys looking to buy the above saw from chainsawbars.co.uk.Β
Trying to decide between the 12 and 14 inch bar, would like to go for the 14 but want to make sure the saw can cope with it.
Anyone any experience of this combo?
Thanks
Ive the 2511 on a 10", think its a great combo! (mainly pruning and small fells/trees with small diameter branches)
Β
Theres no way i'd consider running a 14" on a standard saw.
14 is way to much 10 12 max and to be honest i wouldn't go panther i don't really rate them they don't last if im honest if you order a 2511tes it will come with a sugih 10 pro carving bar witch is worth its wight in gold or if your gonna go 12 fork the cash and get a sugih pro light for it they last years the bars doΒ
Β
Mines had an exhaust mod. Run on 10” bar. Perfect. A Long bar on it would be too much and defeats the object of having a small light saw.
Same re panther. The nose splayed apart after about 4 chains. Was told this is normal for them so I went for a Sugi replacement. Only a couple of chains in but seems fine.
10” and a stihl bar with exhaust mod is my 2511 set up... pretty happy with it and use it for pruning , bucket work and small takedowns... can’t fault it to be honest.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
