What's people's overall preferred bar length for bucking which is most of what I do.
Up until now have only had a 14" bar and am about to buy a new saw for chopping up firewood ... it'll take up to a 20" quite easily but I think that'd be overkill for what I want to do with it but may possibly buy a 2nd larger bar down the road when money permits.
Tempted to go with a 16" for weight / ease of use and for cut after cut it'll be that fraction faster ... interested to hear what others preferred  would be??
Expand
Depends on timber diameter and power head capacity . Quick rule of thumb is take engine size and divide by 3 will give max bar lenght in inches . E.G. 60cc saw divide by 3 = 20inch bar  max .
Edited by Stubby
This chainsaw is useless it hardly cuts anything.
Pass it here let me have a go.
Bloody hell what's that noise it makes ?
That's the engine 😲
@Witterings  16" will do you fine. Cutting from both sides  = 30"  remember the longer the bar the longer to sharpen it. Cut big log into a sharpening pillar (  just over waist height)  near yr stack. Drill holes ito sides fr yr files n spanner. K
I'm going to go against the grain a little here. I'm 6'2 and I prefer a much longer bar so I don't have to bend over and throw my back out the whole time. I've put bigger than recommended bars on saws before just to save me bending over, however if I put a big bar on a small saw I would still only cut small logs. Plus if you're looking at buying a new saw then a bigger saw with a bigger bar will be safer and more future proof. Small saws with dinky bars kickback more aggressively and you often find yourself in strange work positions.
Read more
