On 08/12/2020 at 20:37, Ratman said:
What saw is it? might shed more light on the situation.
.... Appen it might be a Chainsaw,   happy to be wrong tho 😋 K
Edited by Khriss
Drum drive pumps can be motored witha dremel tool n rubber tip as a quick n quiet check
Greetings All;
I have finally got the machine back together after removing the oil pump and oil pump tubing.
I cleaned them off and used WD-40 in a spray can as a low pressure spray.
The inside of this housing was loaded with sawdust mixed with oil, so clean this area out with
Kerosene and a clean rag. I place the blade and bar back on the saw and tested it.
Oil is now flowing freely from the Bar/Chain. Hurray!
The issue I believe was a restriction or plugging up of the tubing running from the oil pump.
As they say alls well that ends well!
Thank you to those that tried to help and provided good comments and instructions.
Thank Again
  • Like 6
22 minutes ago, Al Slitter said:
Greetings All;
Thank Again
Every time you refill wipe the area around the filler before you open it .
37 minutes ago, Al Slitter said:
What do you recommend as a washing agent?
Whatever gets tank deposits out, i usually use old two stroke, then fill up right away, wash caps too. K
WWW.EBAY.CO.UK
Chain saw grinding accessories: 70mm / 50mm. Usage : It can be easily screwed on the electric grinder, and the chain and comb knife can be easily sharpened. Magic Ball Candle Mold Silicone...
Bit of a fiddle to fit to yr grinder but cuts nicely without burning an 3 sizes fr yr various chains.
