On 12/11/2020 at 19:14, Rough Hewn said:
You won’t find one.
Will have to be cut to order.
Do you know how thick that would need to be so it didn’t tear itself apart?
And how heavy??????
I hope you’ve taken a massive non-refundable deposit?
And given your client a 12-18 month lead time?
Ok, so how thick would you say it needs to be so it didn’t tear itself apart - if you don't mind me asking ? ?
Ok, so how thick would you say it needs to be so it didn’t tear itself apart - if you don't mind me asking ? [emoji16]
Depends on species and how you move/lift it,
Pith quality etc.
Personally I’d go 4”-8”.
[emoji106]
You'd be amazed how strong a 3" board is at that length, it's not going to break.
2 guys will move it if you don't mind some scuffs, 4 strong lads no bother.
find a local guy with a big Alaskan then just call up your local tree guys and fish out a dead stick from the log pile.
or do what I did, bought the big Alaskan, took down 1 of the customers trees and milled that.
Job done !
Job done !
Let me get this straight.
You cut a slab 6.8m x .85-1.6m x 3”?
Then got two guys to lift and move it?
Job done !
Your barking mad pal.I have 1m wide x 3m long x 100 mm thick and 2 men cannot move those
Edited by topchippyles
Just now, monkeybusiness said:
Don’t forget Steve is a sweaty, not some weedy valley dwelling sheep shagger...
He can be fooking king kong pal. 2 men would not move a 6.7m x 1.6m x 85mm walnut in a million years. (dick)
The following link is about a 13m long table made with single lengths of bog oak which is surprisingly thin, about 39mm after drying. The pictures show a plank being carried by about a dozen people.......!
Andrew
WWW.THEFENLANDBLACKOAKPROJECT.CO.UK
Our aim is to transform a 4,800 year old Fenland Black Oak into a spectacular 13 metre long table for the nation.
Ok I see a misunderstanding here.
I’m not talking linear, it’s fibre cohesion.
Lift a 3m x 2m x 50mm board up from the sides it will probably split down the middle.
That bog oak was under 2’ wide.
[emoji106]
