Will be ok if you use toe tip bucket, we load with std grain bucket and can tip over side but bucket dips into body of lorry so needs bit of thought to get full load.
If it’s needed to load chip into a high cube walking floor you will need something a bit bigger, at 6mts you won’t be able to tip in the centre of the truck bed and it will be a faff to get an evenly distributed load.
Bob
Yes we used a loading shovel with a tip-on-the-lip grain bucket, 17 lifts to 24 tonne, the JCB 535 also did it easily but 54 lifts to the load with standard bucket.
  • 3 months later...
I think 4.8m is the actual height of an artic.
I've got to get a telehandler too now & 7m is ideal I'd say [emoji106]
Damn expensive machines to buy 2nd hand in the current climate....
