MS211c weird problem
Dinosaw
Hi Guys
211c I took in part-ex. Very little use. Turns over perfectly without the sparkplug. Replace plug and it is like pulling over a 1000cc saw. No fuel in crankcase, piston clean and smooth. Can't even pull it over properly to get a reading on compression tester. Ideas very welcome, got me stumped. TIA.
Hi Guys
Blocked exhaust? Correct plug and not too long?
Is that the "Easy Start" model being the 'C' ? If so, it's got an extra spring between the pull cord and the crank....  I'd be looking there. Actually, I'd take that start cover off, toss it over my shoulder and reach for a standard side cover to try.
I was just starting to consider that possibility myself, if it is an easy start model, that's definitely not working!
