These rackings are able to hold 2 tonnes, if you fancy putting a large log on board ?
That Oak log is 7ft x 16", I doubt aluminium would hold up well.
Just uploading a YouTube video!
Laying on the sofa with a bad back Simon, Whats you username or whatever on YT?
:( Nothing worse. Added to the pain is the frustration of not being able to do anything.
Ive got a drawer full of Morphine if you need any. :D
20 hours ago, Big Beech said:
Only negative is the change of height after every cut.
Would it be possible/easier to raise the log somehow?
I've tried a similar setup but on a much smaller scale for milling a few alder logs I can managed to lift. I've just used old fence posts for the frame and after the top cut I use 4x2s to lift the log up 2".
These lumps of Burr Oak, are the remains of the big Burr Oak i felled 5 years ago, some of you may recall the original post!
I managed to extract them today as the terrain was dry enough, and I cant wait to see the boards they will yield!!
Oh and I'd totally forgotten about the 5" quater sawn beams i left behind as I couldn't move them at the time. Just make them out at the back ?
Edited by Big Beech
