2 minutes ago, Will C said:
@Mick Dempsey your not showing off just working smarter not harder
Thanks, but I assure you, there’s some showing off going on.
I eschew logging for clients for the most part, I always say, “if it can go in the chipper, it goes in the chipper” but these peeps were in my village and it was easy enough.
On 05/09/2020 at 09:39, ESS said:
Yes,..knocked them up on site just driving poles in the ground. Works quite well.
Love that idea. Sometimes the simplest are the best!
On 05/09/2020 at 09:41, kevinjohnsonmbe said:
Also, worth considering making it big enough for a barrow to slip in underneath - cut, drop, move with minimal picking up.
I was thinking of having the base as a pallet so that it was portable, lift-able (and maybe tip-able).
But also along similar lines as yourself with the cut logs falling into something below to save handling again. I was thinking a dumpy bag below, but not sure how I would have it that the pallet was strong enough to lift on pallet forks but with a hole in it big enough for the logs to fall through.
I have seen these so that they mount onto the back of a pickup and pivot at the base  so they just tip strait in .
49 minutes ago, nepia said:
Correct.  I did edit to say 'not here and I can't delete the pic' but my edit wasn't saved either!
Understood . :)
