11 hours ago, nepia said:
I have one at home here and it's nothing like a cube; I couldn't move one that held that much.  Thx anyway
No I use them, they're less than a bulk bag so I reckon only actually half a cube.  And yes probably wouldn't last very long if moving them a lot
Ta daaaah!  Found a guy 40 miles away with two different entries on the Bay; asked him how many he actually had and picked up six today.
I don't want the bottles but finding cages alone.... well it's difficult enough to make me start a thread on the subject.
In the highly unlikely event that anyone has a use for six bottles with working caps and taps then fill your boots; they're in west Kent on top of the North Downs.
Cut the tops off and screw them to a wooden pallet. Add air holes if for logs. Cut them down to whatever height. I have some knee high crates for running tools around in. Easy to reach into.
Will they last forever? No. Will they last long enough to be worth the twenty screws and twenty minutes? Only you can answer that but let's presuppose yes.
When you cut them, make sure to do it somewhere outside of the environment so as not to pollute it with plastic swarf.
Edited by AHPP
@AHPP   I'd rather not keep the bottles at all if possible so I'll offer them to anyone who'll listen.
I don't actually see why they couldn't be used static on a pallet (rainwater harvesting?); wouldn't a ratchet strap round the middle be sufficient to maintain shape?  As said all taps and caps are in good order
I’m sure they could. Or in groups to reduce the number of straps you need. Or buried. Or or or.
You could keep them and store water yourself. It’ll seem like a waste of time until you need it.
Cut in half and one up-ended, they make great tree nurseries.
Here's the team potting on oak trees, from a few hundred acorns shcattered into each tub. The owner of these ones cut the cages too, but they aren't needed to hold their shape.
They can also be used as raised beds for vegetables, fruit bushes, etc. The outside could even be clad with something for aesthetics.
I'd be using them for water storage I think, suitably reinforced around the sides if necessary. (Water is going to be at a premium soon, as we've had no rain to speak of in weeks now. )
