If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
AnnaE
Hi there
I'm new here - I've got a client who has some trees in his back garden.
There was ivy growing up the tree and he tells me he got a tree surgeon to remove the ivy. However, he sent me a photo of the work and the bark has been removed in a large section all around the trunk.
My husband tells me this is called "ringing" and a google search suggests that this is used to kill a tree - although it did suggest that oak trees can withstand this.
Has the tree been damaged beyond repair? Is there anything that I should do - is this the normal way to remove ivy?
i can see that the ivy hasn't been touched at the root so it looks to me as if the ivy will just grow again anyway.
I'm so grateful for any advice.
Photo of tree with ivy rem(7208287.1).doc
14 answers to this question
Register a new accountSign in
