Big battery question
Rough Hewn
1 hour ago, Rough Hewn said:
Does this mean it runs on single phase at 12 amps?
No it means that connecting the 3 phases in delta (instead of star) it will draw 12A.
Simply put the star and delta refers to how the 3 coils / windings of the motor are connected to the supply, so in star one end of each winding is connected together, in delta you could say they are daisy chained with the end of one coil getting connected to the start of the other.
No it's 3ph and draws 12 amps when switched as delta and  7 when switched as star. I think that means you start it star and then once it's running switch to delta although both those voltages time Amps give the same ~2.7kW
it makes 2.7 kW with a power factor of .8 so you need to supply 1.25 as many amps at the voltage to get that power.
A 3ph Tesla powerwall perhaps might run it.
2 minutes ago, Rough Hewn said:
There's an old 3ph Saw on eBay.
Thought about using fir milling.
Then thought hmmmmmm.
5kg battery and transformer.
10-30 seconds run time is proof of concept?
Just don't want it to explode....
Pm me the link and i will look at the plate rating for you
