Guys
Any ideas of a cheaper alternative to a genuine ifor williams pump on a tipping trailer...it lifts up so far and just spins as if now doing anything.
Are they repairable?
Is there a similar pump from something else that will do the job?
Thanks in advance ?
+1 for low level..
Re: replacement...maybe this?
WWW.FLOWFITONLINE.COM
"Flowfit 12 V DC single acting hydraulic tipper power pack, 4.5 / 8 litre reservoir c/w 2 button pendent. 5 l/min @ 160 bar...
much cheaper than the full bore Ifor Part though.
https://www.barlowtrailers.co.uk/Ifor-Williams-Hydraulic-Power-Pack-FG515-12v--P11974
Edited by Bob_z_l
Fill the oil up - sounds just like a low oil issue if it gets everything moving in the first place.
The flowfit pumps are excellent value for money but make sure you get one with a big enough oil reservoir...
Also, unless you pay quite a bit extra you will lose the manual pump facility with the flowfit version.
Which is handy when ever so slightly overloaded.
Manual pump sod that, forgot lead once when delivering logs went to tip  it up by hand pump it was quicker to chuck them off by hand.
Edited by woody paul
I discovered once when I forgot my lead, that you can put a piece of wire in the plug outlet from the top left to the bottom and it will make the trailer go up , r
top right to bottom to make it go down.
Made my tipper wireless now which avoids having to have a  lead, and meaning you can tip from the vehicle seat!
