Has anyone got or tried out a Line Launcher 40 002 Series?  It uses Firearms .22 blank cartridges to launch a throwlin. But if you can aim it and it was accurate, it could save a fair amount of time messing about.
Interested in people view if you have tried it out..
UK Importer: https://workware.co.uk/product/40-002-rl-series-line-launcher/
Sold Here: https://www.northernarbsupplies.co.uk/catapults/2998-line-launcher-0084882003250.html
Video Here: https://www.youtube.com/watch?v=wZOY-5RSHxY
That’s not cheap! I doubt it’s very quiet either!
I have made an air cannon from a ball valve and scaffold tube, pump up with a track pump and it will cope with most uk trees and is really accurate
Got a firearms ticket more than 12 ftlbs and you have a section 1 firearm
3 hours ago, RDB logs said:
I’m fine on both!
Is the device on your firearms certificate?
I don't  see it as being worth mentioning even if technically required.
I wonder what the view is on those kids rockets you pump up and the blow out a jet of water to propel themselves.
I was meant to be ironic , he’s made a air powered bazooka with which much fun can be had you cannot be too careful especially if you hold a fac, spoken from experiance
Edited by dumper
Sold Here:
WWW.NORTHERNARBSUPPLIES.CO.UK
Order our Line Launcher 40 002 Series from Northern Arb Supplies. Visit us online or call us to place an order!
I actually own one and there classed as a dog dummy trainer apparently.
Pros:
sounds like a cannon,
Has a good ability to punch through brambles and fire high over objects for winching, zip lines, dragline etc.
Cons:
Dummies which I have are quite light sadly.
It makes a hell of a noise.
Not as accurate as I'd hoped but others may be better than me.
I also own 2 air launchers. 1 for throwbags and 1 for throw pods.
Not control for height really.
Pros:
Very accurate,
You can adjust the amount of force you put in for height.
Easy to Store,
Doesn't mind water,
Doesn't make a huge sound,
Everyone prefers it.
Great for setting any type of line application really.
Cons:
You need a bike pump or compressor with you.
There about 1.5m long.
you don't need a firearms license as its not got a barrel ! the small  one is a little heavier and quite accurate but very noisy
