I have been asked to fell and chip trees on site and use the chip to fill a play park, the customer is going to deal with moving the wood from where they’ve been felled to the park area,
Not really sure how to price for this it’s a bit different from what I would normally do so any tips/advice would be greatly appreciated?
Just cut and drop then chip the waste and tip in the play area? Price the job as normal add on labour for raking the stuff about if required set a rate for the extras or just add a few hundred to what you'd normally price? That's my suggestion
Jack
55 minutes ago, Mark Bolam said:
I don’t understand the question.
What would you rather do or go fishing .? Simples ,.
Edited by Stubby
If you’re just dumping the chip and the customer is moving it that’s fairly simple.
If you’re just dropping the trees and the customer is moving them to the play park then you are chipping them, then that’s a different game entirely.
Surely it’s no different only you don’t need to tip at the end of day
Personally the fuel saved is about the same as id get for the chip £10 a tonne here.
Unless it miles away and a fair saving
