It probably wouldn't be recommend by the RHS or whatever, but I have planted hundreds and hundreds of daffodil bulbs in grass using a fencing pinch bar, and if the ground is soft close the hole with your heel, or if you're stuck backfill with a handful of compost/soil.
Back in the early 90s me and some others planted 10s of thousands of daffodils at Groombridge place (pictured)
We found digging out a spit square with a sharp spade and putting a bulb in each corner worked best.
Edited by Mick Dempsey
  • 3 weeks later...
But not too deep or they could come up blind. Easy to overdo it with an auger I'd have thought.
What about slot planting them using a narrow drainage shovel?
Edited by Gimlet
