Hi,
I have a lot of beech oak and cherry, several tons of each.
I find that the cheery does not burn nearly as well as the oak and beech - especially the beech.
Is this a normal thing or are my expectations too high? I have a moisture meter and all are nice and dry right through the middle - below 20% some are 10%
I am just wondering because you see many forums saying how wonderful cheery is and the lovely smell - I don't get either of those things.
Cheers,
Edited by CEE
correct spelling
Beech seems to be the king. Easy to split burns fantastic when dry. And plentiful in the chilterns where I live.
The cherry I have was very old - the trunk lay in the woods for maybe 4 years - is there such a thing as it being past it's best ?
Yes and maybe it is; cherry doesn't keep well on the ground.  Get hold of some that's in good condition, season it properly and try it; it's good stuff.
Yes definitely, all the time it is lying and the moisture content is high the microbes that feed on the wood are reducing it's dry matter, and the volatiles that give a lively flame seem to go first. Also cherry bark is waterproof so the wood rots inside it, producing CO2 and water, thus it does not dry. It is similar to birch in this respect so best felled crosscut, split and stacked under cover asap.
You also find this with old bits of stagheaded oak which are dry but not very exciting to burn
I would agree that wood does "go off" if left out in the wet too long then dried, especially the species with a high carb content like sycamore and other maples. I've had syc that lay out for a year and then was brought in split and dried and went all powdery in the middle., it burned but wasn't up to much.
Fruit wood used green on an open fire with other dry hardwood can produce a very faint fragrance.
I used to sell bay wood green to a Jamaican restaurant for BBQ smoking meats. Apparently in Jamaica they use pimento wood, and bay is the closest thing in the uk.
I presume once fragrant wood has dried it has lost all essential oils/phenols/volatiles etc.
[emoji106]
