Been helping a neighbor today trying to help them out .spent most the day rotavating which turns out to be hard work .anyway they had  pulled out a large apple tree root with there car and told me they had jet washed off any remaining crap
said ok I will saw it up for you as it didnt look too dirty .anyway before cutting switched to max oil flow and a few minutes later this is what is left of a new Stihl chain and bar and completely dull ..I'm not sure what was inside the wood but a lot of sparks flew of the chain .looks like waste of a good chain I guess I will know for next time the answer is no
  • Sad 1
True .probably obvious this would of happened .looked at it though seemed clean enough and thought it would be probably be alright .was it probably a stone in there which caused the sparks ? Never seen a new chain go that dull in a few seconds
True probably  not ideal job for a nice new chain but the trunk was bit big for an old 15'' chain which was the only worn out one I could find .lesson learnt anyway don't cut anything from below the ground
I was cutting a trunk down at the farm and hit a stone. It took two teeth out of a reasonably new 20" chain. :( Still using the chain though and it still cuts.
