Over the past 10 years all of the timber we have ended up with from tree surgery has gone for firewood. I've being wanting to have a go at milling for a long time but have never really had chance to have a go. I have a lot of oak beech & elm in 3-4 meter lengths just sat around doing nothing, I am wanting to have a go at making them into table tops etc. Am I best off getting an alaskan mill type jobby or just jumping in and buying a mobile band saw? I like the idea of the band saw as we have the space to use it and machinery to load it etc... Suggestions???? Advice???
You've got a 660/661/880?
Get a cheap Alaskan mill,
A straight ladder and a day off.
Do a few logs with that.
Remember bandsaws are limited in size of cut.
Often only 60-90cm.
And cost thousands.
You can get a panther mill and big bar off Rob.D Chainsawbars UK for a few hundred quid.
Then when you've filled your garage and shed and any spare space with milled timber...
Then you get a bandsaw.
[emoji12][emoji106][emoji106][emoji106]
Often only 60-90cm.
And cost thousands.
So would you be able to cut a wider slab with a chainsaw over band saw?
Silly question but is it just a case of once they are cut stack them somewhere dry and breezy to dry them out?
Think I best stick to the alaskan for now as I've never done it before. Would be a fraction of the cost... Those panther ones look nice to use. Has anyone used one before?
Big J is correct about bandsaws. [emoji106]
And chainsaw mills[emoji848][emoji12]
I've got a mate with a panther, he loves and rates it highly.
[emoji106]
Maybe another option would be to hire someone in with a portable bandsaw? If you've enough timber to feed it for the day and equipment to move it.
Or, what about Lucas mill? I've not used one but they seem in between in terms of cost and performance. Certainly you could get someone to come and set up in your yard.
I set off with a chainsaw mill which gets you hooked on wood ‘ then moved on to a woodland mills hm130 which is still hard work I was thinking of upgrading to a hydraulic mill but went out chainsaw milling in the lakes and wow seam to got my mojo back with cutting wood
