44 minutes ago, AHPP said:
Are hardwood beams usually cut full dimension (as opposed to nominal dimensions commonly used on softwood where a 2x4 is actually 1.75”x3.5”)? So would an oak 2x4 actually measure 2”x4”?
Depends on what you're planning to do with it. If I was asked to cut timber which would be dried and planed to end up as 2x4 I'd cut it oversize by 1/4 inch but if its just going to be used as a rough sawn 2x4 then I'd cut it at exactly 2x4.
Spot on! When working as a joiner we would cut sawn timber to about 1/8"-1/4" oversize, this would allow us to straighten it when planing maybe a bit more if it was a really nasty grain.
Not done anything with the logosol M7 since september but have a load of logs coming this week and weather forecast is looking good end of the week so looking forward to getting some milling done
Whats the cost of the lucas mill?
20 minutes ago, Rough Hewn said:
Running the stihl ms881 on the 60” panther mill through 34” oak.
And a small cherry stick.
IMG_1614021917.262219.jpgIMG_1614021929.238250.jpgIMG_1614021941.054360.jpgIMG_1614021959.937370.jpgIMG_1614021972.494269.jpgIMG_1614021985.198816.jpgIMG_1614022001.438166.jpgIMG_1614022013.553064.jpgIMG_1614022024.920107.jpgIMG_1614022038.580663.jpg
Beautiful wood! Love the oak!
 Question for the enlightened. Is it worth having a small milling bar for those logs of 15" or less diameter? I have a 36" and 48" bar, have some smaller logs,  yew, alder, ash which I want to mill up, just wondering if there is any point in getting a 20-24" bar on a small mill?
Yes.
Or get a Logosol saw bench.
[emoji106]
5 minutes ago, Rough Hewn said:
Yes.
Ok ta. That's all I wanted to know. Yes logosol F2+ for christmas I hope. Well maybe before if I can get some more of this timber moved. :thumbup:
